Nut tap
Nut tap is a specialized tap used in mechanical processing to machine nuts (nuts)
Characteristics of Nut Tap
Using internationally renowned professional tap grinders imported from Germany, showcasing high-quality thread grinding technology and strictly controlling the accuracy of taps;
Using diverse groove types for different types and processed materials to enhance chip removal performance;
Using a specialized coating for Barcas taps effectively extends the lifespan of the taps.
Types of Nut Taps
1 Short handle nut tap
Customers can connect the bent handle themselves for easy replacement of new and old taps;
Widely used in the fastener industry for the processing of conventional nuts and specialized nuts for railways, wind power, automobiles, engineering machinery, and other industries
2 thread handle nut tap
Can be paired with the threaded sleeve used by the customer to connect the bent handle,
Significantly reduce the adjustment time before processing;
Use threaded connection taps to bend the handle,
It can also reduce the risk of tap breakage when the tapping torque is too high
3 large specification nut taps
The handle is a square flat structure, which is convenient for customers to drive and use
Accuracy of nut tap
Using the same precision level as the Japanese OSG nut tap (GH precision level)
The tolerance for each level is 0.0005 '' (inch), which is 0.0127mm.
Close to customer usage habits and convenient for customers to choose from.
Comparison of lifespan with competitors
At 48 hours
(Customers use nut taps to process nuts)
(Finished nuts processed by customers using nut taps)
Nut tap is based on thirty years of tool manufacturing experience, adhering to the craftsmanship spirit of "a little difference, a lot difference", with the aim of serving customers and using our expertise to solve their problems.
下一篇 Thread plug gauge
